Based on contributions by Sem.db.
If one end-effector has more than one working point (e.g. two different tool tips, or a tool used in two orientations), define multiple tool center points (TCPs) and switch between them in your program instead of using a single fixed TCP.
- A Universal Robot with PolyScope (script manual reference: PolyScope 5, §15.1.47
set_tcp). - Each TCP already defined using the built-in TCP configuration tool: Installation → General → TCP.
1. Define each TCP
Use the built-in TCP tool under Installation → General → TCP to find the pose of each tool point. A TCP pose has the format p[x, y, z, rx, ry, rz]: the first three values are the XYZ offset in meters, the last three are the rotation (axis-angle) in radians.
TCP1 = p[-0.00025, -0.20739, 0.13121, 1.3090, 0, 0]
TCP2 = p[-0.00152, 0.00074, 0.27498, 0, 0, 0]
2. Switch the active TCP with set_tcp()
set_tcp(TCP1)
# ... code using TCP1 ...
set_tcp(TCP2)
# ... code using TCP2 ...
Add a short sleep() before switching TCPs to make sure the robot isn’t moving when the change takes effect.
3. (Recommended) Move to a neutral position before switching
Switching TCP effectively changes where the tool point is and how it’s oriented. If you switch while the joints are in an extreme position, the new TCP’s motion can overextend a joint. Move to a neutral, standard joint position first:
standardpos = [1.57078, -1.57077, 1.57082, -1.57078, -1.57078, 0]
set_tcp(TCP1)
movej(standardpos) # go to a neutral joint position before switching TCP
sleep(0.5)
set_tcp(TCP2)
movej(standardpos)
This step is not strictly necessary, but it avoids joint-limit problems when the two TCPs have very different orientations.
- Switching TCP while the robot is still moving — always add a
sleep()beforeset_tcp(). - Using
movelinstead ofmovejfor the move to the neutral position —movejgives you direct control over joint rotation, which is what you want when recovering from an extreme pose. - Forgetting that
set_tcp()changes are stateful: any motion command afterset_tcp()uses the new TCP until you switch again.
- How to set the payload and center of gravity on a UR e-Series robot — re-check payload and center of gravity if your TCPs correspond to tools with different weights.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: How to use multiple tool center points on a UR robot.
