Based on contributions by Job_Valkenburg.
A finger joint (“fingerbox”) is a strong, glue-free way to join two edges of laser-cut wood plates. This shows how to add fingers to one shared edge between two already-designed parts in Autodesk Inventor; repeat the same process for every edge of your part that needs joining.
- Autodesk Inventor. It’s free for students — see the Autodesk education access page to sign up.
The confirmation email is often delivered to your spam folder, not your inbox.
- Basic familiarity with Inventor sketching and part modelling.
- Two wood plate parts you want to join, fully defined (no dimensions left free to change).
This example joins two wood plates as shown:
Make sure both parts are fully defined before you start, so no measurement can shift while you’re joining them.
1. Sketch the fingers on Part 1
Enter the sketch of the first part and sketch a “finger” on the edge you want to join. Set the finger’s height equal to the thickness of the plate of Part 2 — that’s what the finger needs to slot into. The finger’s width is less critical; keep it in the 10–40 mm range.
2. Pattern the fingers on Part 1
Use the Rectangular Pattern tool to repeat the finger along the edge:
- Select the three sides of the finger.
- Click the arrow at “Direction 1”.
- Click the line along which you want the fingers to repeat.
- Set the spacing between fingers to double the finger width.
- Fit as many fingers on the edge as possible, adjusting by trial and error.
- Click OK.
- Extrude all the finger surfaces.
Part 1 is now finished.
3. Sketch and pattern the fingers on Part 2 (inverted)
Do the same on Part 2, but inverted — Part 2 gets slots cut in, rather than fingers sticking out:
- Sketch the finger shape into the part instead of on top of it.
- Set the distance between the edge of the finger cutout and the edge of the part to the same length used on Part 1.
- Use Rectangular Pattern the same way as Part 1.
- Extrude everything except the fingers (i.e. cut the finger slots out, leaving the material between them).
The result looks like this:
4. Check the fit in an assembly
Constrain both parts together in an assembly to verify the fingers mesh correctly before sending anything to the laser cutter.
- Fingers don’t line up between the two parts — recheck that the finger spacing (double the finger width) and the starting offset from the edge match on both parts.
- Joint is too loose or too tight — the finger and slot dimensions in this guide are nominal (no laser kerf compensation).
Check: if your fit is consistently loose or tight, ask the workshop about the laser cutter’s kerf width and compensate the finger/slot dimensions accordingly; this wasn’t covered in the source material.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: How to design a connection with laser cut wood (aka. ‘fingerbox’).
