How to design a SolidWorks camera mount for the Intel RealSense D435
Based on contributions by Elmerisalama.
The Intel RealSense D435 only has one large threaded hole and two small ones on its body, which on their own aren’t enough to hold the camera securely on a moving setup. This walks through a three-part mount design that clamps onto standard aluminum profile and lets you adjust the camera’s position, rotation, and downward angle.
1. Design a holder for the aluminum profile
Model a holder for the 40×40 aluminum profile using the profile’s CAD file as a size reference. Design it so it can slide along the profile before being clamped in place, and so it can be attached to any side of the profile depending on your project’s layout.
2. Design the swivel mount
Design a second part that attaches to the profile holder and lets the camera rotate. In this design the two parts are tightened together with a nut that passes through both parts and is secured to the aluminum profile, allowing 360° rotation before it’s locked in place.
3. Design the camera holder
Design the final part: the piece that actually clamps the camera. Attach it to the swivel mount with a nut so the downward angle of the camera can be adjusted independently of the rotation set in step 2.
Add side holes for screws that secure the camera body against the holder, so it stays stable during the robot’s movement. Add a thin layer of padding between the screws and the camera body — this lets you tighten the screws enough to hold the camera firmly without damaging it.
4. Assemble and check
Assemble all three parts with the camera to confirm the full range of adjustment (position along the profile, rotation, and downward angle) covers what your project needs.
  • Camera is loose using only its built-in threaded holes — that’s expected; use the three-part clamping mount above instead of relying on the camera’s own mounting holes alone.
  • Screws crack or mark the camera housing — add (or thicken) the padding between the screws and the camera body.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: Solidworks Camera Mount Desing for Intel RealSense D435.
