How to model a 3D-printed press-fit bearing mount (intermediate parametric CAD tutorial)
Based on contributions by Jeppe.
This intermediate tutorial builds a 3D-printed bearing mount that press-fits a radial bearing. Use this pattern whenever your design needs an axle (or similar) whose movement is constrained by a bearing, and you want the mount to scale to different bearing sizes.
  • Any parametric CAD package (Inventor, SolidWorks, or Fusion 360).
  • Comfort with basic parametric sketching and the parameters/equations tool — see How to model a parametric coffee cup (beginner parametric CAD tutorial) for how to create a part and open the parameters list.
  • The bearing’s outer diameter, inner diameter, and width, plus your bolt size.
1. Set your design goals
Before modelling, define what needs to stay adjustable:
  • The press-fit tolerance needs to be adjustable, so you can dial in a perfect press fit for your specific 3D printer’s tolerance. This tool gives approximate starting values for 3D-printed fits.
  • The bolt hole size needs to be adjustable.
  • The whole mount should scale with bearing diameter and width, so you can reuse the same model for other bearing sizes.
:warning: Check: the tolerance-fit link above is a third-party tool for approximate press-fit values, not a guaranteed value — always print a test fit before committing to a final part, since press-fit tolerance is specific to each printer.
2. Add the input parameters
Add the following parameters to your part (see How to model a parametric coffee cup (beginner parametric CAD tutorial) for how to open the parameters tool in your software):
At minimum you’ll want parameters for bearing outer diameter, bearing inner diameter, bearing width, press-fit tolerance/offset, and bolt hole diameter.
3. Model the mount
Follow the recorded walkthrough to model the part step by step:
If a tool used in the video isn’t available under the same name in your CAD software, search for the closest equivalent — most parametric CAD packages have a matching feature.
  • Press fit too tight or too loose — adjust the tolerance/offset parameter and reprint a small test ring before printing the full mount; printer-to-printer tolerance varies.
  • Mount doesn’t scale correctly for a different bearing — make sure every dependent dimension in the sketch is driven by the bearing diameter/width parameters, not typed in directly.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: Intermediate parametric CAD Design tutorial (3d printed bearing mount).
