Based on contributions by Okay.
Ultrasonic and IR (infrared) distance sensors are commonly used to detect boxes on a conveyor belt, for example to trigger a conveyor stop or tell a robot when to pick up or place an object. This guide covers wiring, basic Arduino code, and testing for both sensor types.
- Ultrasonic sensor (e.g. HC-SR04)
- IR sensor (e.g. GP2Y0A21YK0F)
- Arduino (or another microcontroller with digital/analog I/O)
- Breadboard and wires
- 5V power supply for both sensors
- Boxes of different sizes to test with
1. Understand the two sensor types
Ultrasonic sensors emit high-frequency sound pulses and measure how long the echo takes to return, converting that time into a distance. They work well for irregularly shaped or transparent objects and are suited to longer-range detection, object counting, or level measurement.
IR sensors emit infrared light and measure the reflection. They respond quickly and are best for opaque, non-reflective surfaces at shorter range — useful for edge detection and more precise positioning.
2. Wire the ultrasonic sensor
- VCC → 5V
- GND → Ground
- Trig pin → a digital pin (e.g. pin 9)
- Echo pin → another digital pin (e.g. pin 10)
Double-check the wiring before powering it on.
3. Wire the IR sensor
- VCC → 5V
- GND → Ground
- OUT pin → an analog input pin (e.g. A0)
The IR sensor’s output is analog, so it must be read through an analog input pin.
4. Program the ultrasonic sensor
const int trigPin = 9;
const int echoPin = 10;
long duration;
int distance;
void setup() {
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
Serial.begin(9600);
void loop() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = duration * 0.034 / 2; // Speed of sound: ~0.034 cm/µs, divided by 2 for the round trip
Serial.println(distance);
delay(1000); // Wait 1 second before the next reading
This sends a pulse, waits for the echo, and prints the calculated distance (in cm) to the Serial Monitor.
5. Program the IR sensor
const int irPin = A0;
int irValue;
void setup() {
Serial.begin(9600);
void loop() {
irValue = analogRead(irPin); // Read the raw analog value from the IR sensor
Serial.println(irValue);
delay(1000);
This prints the raw analog reading, which changes with the distance to the object. Convert it to a distance using your specific sensor’s datasheet curve if you need actual units.
6. Position and test on the conveyor
- Mount the sensors where the boxes will pass. Ultrasonic sensors should point perpendicular to the box surface for the most accurate reading; IR sensors should point directly at the object.
- Watch the Serial Monitor while boxes pass: for the ultrasonic sensor, check that the measured distance matches the real distance; for the IR sensor, check that the analog value changes consistently as a box gets closer or farther away.
- Adjust sensor height/angle if readings are inconsistent or boxes are missed.
- How to drive a stepper motor with Arduino or Raspberry Pi — driving a stepper motor with Arduino or Raspberry Pi
Rewritten and consolidated (Sept 2026) from the original student how-to’s: How to set up and test Ultrasonic and IR sensors with an Arduino for object detection on a conveyor.
