Calibrate a robot and a camera
Did you already solve this problem?
Just edit this wiki post!
Please provide a step-by-stap solution, including all the code and other things someone else would like to know to make it work.
Explain:
  • What exactly is calibration?
Steps for calibration:
  1. Camera: exact transformation from pixels to mm’s
  2. Robot: transform camera mm position to robot mm position
Calibrate using OpenCV
