@4lloyd, a question:
I’ve got the following PLC programme:
Which is communicating with this Python code:
def check_transport_band(conn):
number1 = 0
data = conn.recv(512)
print("Data received from PLC")
print("Raw: ", data)
print("Error while receiving data. Error message: ", str(e))
return None
if not data: return None
if (len(data) == 6):
number1 = int(struct.unpack(">h", data[0:2])[0])
print("Number 1: ", number1)
print("Received too little or too much bytes. 6 needed, received: ", len(data))
if number1== 1:
# or number2 or number3
print ("owkee")
return True
print ("ownee")
return False
Now, the first time start the programme, when the starting signal is (0/ band off), I receive data which has a length of 6 bits (as expected).
However, the second time around I receive 24 bits:
When start the programme, when the starting signal is (1/ band on), I receive data which has a length of 6 bits (as expected).
However, when i turn it of it starts to range between 30 and 24.
Would you have any idea what’s going on here?
