Did you already solve this problem?
Just edit this wiki post!
Please provide a step-by-stap solution, including all the code and other things someone else would like to know to make it work.
Connecting to the Kawasaki to send single locations
Connect over TCP/IP (by @Shiyar)
Connecting a Kawasaki Robot to a Python program on your computer was challenging, but we developed a solution using sockets. To facilitate this connection, set up the Python program as a server, allowing other devices, including the robot, to connect to it. This can be achieved using the following code:
Python code on computer
def start_server(host, port):
server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_socket.bind((host, port))
server_socket.listen(5)
print(f"Server is listening on {host}:{port}")
client_socket, addr = server_socket.accept()
print(f"Connected by {addr}")
# data = client_socket.recv(1024)
# if not data:
# break
# print("Received:", data.decode())
# You can send a response here if needed
response = '1'
client_socket.sendall(response.encode())
time.sleep(2)
response = '2'
time.sleep(3)
client_socket.close()
if __name__ == '__main__':
HOST = '192.168.0.2' # Your PC's IP address
PORT = 10001 # Port to listen on (non-privileged ports are > 1023)
start_server(HOST, PORT)
Note: My code includes a segment within the while loop to send data for testing purposes. It sends the number β1β every 3 seconds, alternating with the number β2β on the subsequent iteration.
Kawasaki robot code (AS language)
After that you have to connect the Kawasaki robot to your pc/python program.
I made an script to do that here is the code:
.PROGRAM smr2() ; Shiyar
tout_open = 60
ip[1] = 192
ip[2] = 168
ip[3] = 0
ip[4] = 2 ; PC's IP address
port = 10001
er_count = 0
connect:
TIMER (2) = 0
TCP_CONNECT sock_id1, port, ip[1], tout_open
IF sock_id1 < 0 THEN
er_count = er_count + 1
IF er_count >= 5 THEN
PRINT "Client Communication with PC has failed"
ELSE
PRINT "TCP_CONNECT error id = ", sock_id1, ", error count = ", er_count
GOTO connect
END
ELSE
PRINT "TCP_CONNECT OK id = ", sock_id1, ", with time elapsed = ", TIMER (2)
END
.END
After that, you might want to receive data from the Python program
. This can be done using my script, which receives data and performs actions based on the received data, such as executing Option 1 or 2, etc. You can customize it however you like.
.PROGRAM receive_data() ;
WHILE TRUE DO
numbytes = 10
max_length = 10
tout_rec = 60
ret = 0
TCP_RECV ret, sock_id1, $recv_buf[1], numbytes, tout_rec, max_length
IF ret < 0 THEN
PRINT "TCP_RECV error in RECV", ret
$recv_buf[1] = "000"
ELSE
IF numbytes > 0 THEN
;PRINT "TCP_RECV OK in RECV", ret
FOR i = 1 TO numbytes
PRINT "RecBuff[", i, "]= ", $recv_buf[i]
IF $recv_buf[1] == "1" THEN
PRINT "IT IS 1"
SPEED 80 ALWAYS
JMOVE #[ -100.000,-59.995,9.834,13.745,8.050,50.603]
END
IF $recv_buf[1] == "2" THEN
PRINT "IT IS 2"
SPEED 80 ALWAYS
JMOVE #[ -160.000,-59.995,9.834,13.745,8.050,50.603]
END
END
ELSE
ret = -1
END
END
END
.END
Connect over UDP (by @Shiyar)
Sometimes you need faster solutions, In that case you can use UTP protocol which is very easy to be used in python and also in Kawasaki Robot.
Here is code Robot Code:
.PROGRAM connect_to_pc_by_udp()
timeout = 120
answer_timeout = 3
ip[1] = 192
ip[2] = 168
ip[3] = 0
ip[4] = 10
port = 10010
numbytes = 1
ret = 0
WHILE TRUE DO
TWAIT 1
UDP_RECVFROM ret, port, $cnt[0], numbytes, timeout, ip[1]
IF ret <> 0 THEN
PRINT "No data received within timeout period or error code: ", ret
; Continue to the next iteration without halting
ELSE
PRINT "Message: ", $cnt[0]
; Send confirmation message
$cnt[0] = $ENCODE (/D, numbytes)
UDP_SENDTO ret, ip[1], port, $cnt[0], 1, answer_timeout
IF ret <> 0 THEN
PRINT "Error with the UDP send, code: ", ret
; Optionally handle send error but do not halt
END
END
END
.END
Python code:
def udp_start(HOST, PORT, TRG_HOST):
server_socket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
server_socket.bind((HOST, PORT))
print("UDP server started.")
input("Press Enter to send data...") # Waits for Enter key press to proceed
response = '1'
print("Sending data")
server_socket.sendto(response.encode(), TRG_HOST)
time.sleep(2) # Optional: delay between sends
HOST = '192.168.0.2' # Local IP address
PORT = 10010 # Port to listen on
TRG_HOST = ('192.168.0.1', PORT) # Target host and port
General solution (by @Mathijs!)
TCP or UDP communication is explained in the Kawasaki TCP/IP Communication Manual.
Some detailed examples are available starting at page 46. Please note that some functionality is not available out of the box, you need all the separate programs mentioned to make this work:
- .PROGRAM open_socket() ;Starting communicatin
- .PROGRAM send(.ret,.$data) ;Communication Sending data
- .PROGRAM recv() ;Communication Receiving data
- .PROGRAM close_socket() ;Closing communication
Please note that there might be differences between these functions when acting as server or client!
Example programs
If you want to use the robot as client:
tcp_client.as (3.4 KB)
If you want to use the robot as server:
tcp_server.as (3.6 KB)
Directly controlling the full Kawasaki movements with a bare Python library
Kawapai library by @GuusParis (experimental)
Python library for interfacing with Kawasaki D, E and F series controllers
Warning: API is in experimental stage
Note from @thijs: The Tetrisbot group made improvements to it, but we donβt have that code. I am currently trying to get it and will update this document when I have it.
Update: @tom was kind enough to provide the entire codebase of the Tetrisbot, including improved kawapai lib! Download here: tetris bot code incl. improved kawapai library.zip (3.7 MB)
ROS library
Official, unsupported KHI (Kawasaki Heavy Industry) Ros drivers. Currently only for these robots:
- duaro1
- rs007l
- rs007n
- rs013n
- rs020n
- rs025n
- rs030n
- rs80n
General solution (by @mathijs)
Example programs
ROS library
- duaro1
- rs007l
- rs007n
- rs013n
- rs020n
- rs025n
- rs030n
- rs80n
