Create TCP/IP connection between your PC and a Universal robot
Create TCP/IP connection between your pc and UR robot
This how to will show you bare minimum of establishing communication between the ur robot and your device using the ur script and python script.
Connect your device to ur robot and configure your ip, make sure your ip is within robot’s ip range, something like 192.168.0.xxx
Confirm your device’s ip by typing ipconfig on terminal
Next you can copy the ur script to teaching pendant and run the python script
UR Script
ip = "192.168.78.1" # This is your device's ip
socket_name = "anything"
socket = socket_open(ip, port, socket_name)
while (True);
    # receive the expected 3 floating point indexes of an array
    receive = socket_read_ascii_float(3,socket_name)
    textmsg(receive)
    # send a message
    socket_send_string("Send your strings here", socket_name)
end
socket_close(socket_name)
Python script
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
# Bind socket to your device's ip and port, port can be anything above 1024
# You can't use port that used by other process
s.bind(("192.168.78.1", 5000))
s.listen(5)
print("Server is listening for connections...")
    # Accept a connection from a client
    clientsocket, address = s.accept()
    print(f"Connection from {address} has been established!")
        # Receive a message with expected byte length of 1024 byte
        msg = clientsocket.recv(1024)
        if not msg:  # If no message is received, break the loop
        # Decode message to utf-8 format
        print(msg.decode("utf-8"))
        # Send floating point number
        message_to_send = "(1.2, 1.3, 1.4)"
        clientsocket.send(bytes(message_to_send, "ascii"))
    # Close the client socket
    clientsocket.close()
