How to add safety planes to a Universal Robot
Based on contributions by Jasonbrowne.
Safety planes are virtual boundaries that stop the robot from entering a defined area — useful when the robot works in a confined space or near a person and needs a hard physical limit it cannot cross.
  • A Universal Robot with PolyScope and access to the Installation tab’s Safety settings.
  • Up to 8 safety planes can be configured.
  1. Go to Installation → Features and set up the planes and/or points/coordinates you want to use as limits (e.g. top, left, right, front).
  2. Go to Installation → Safety → Planes.
  3. Add a plane (you can add up to 8).
  4. Open the plane’s Properties:
    • give it a logical name,
    • select the coordinate you created in step 1 from the Copy Feature dropdown,
    • choose the restriction type: Normal and/or Reduced.
  5. Repeat steps 3–4 for every safety plane you need.
  6. Adjust the plane’s displacement if needed, then confirm the parameters.
Configured safety planes stop the robot from breaching the set limits, or switch it into a reduced safety mode as configured. For the full reference, see the Universal Robots guide to setting up safety boundaries.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: How to Add Safety Planes to a Universal Robot.
