How to Annotate and Save YOLO Detections with OpenCV
For this, you will need to have a .pt file for your YOLO model. This will NOT work with an OBB model, you will need to make some changes to the code.
Notes:
• Output Path: Update the output path for saved images as needed.
• Environment: This tutorial/code works on systems with OpenCV, a working camera, and a Python environment with the required libraries installed.
• YOLO Model: Ensure model.pt or your specific YOLO model file is correctly placed and compatible with the ultralytics YOLO library.
Step 1: Import Required Libraries
Ensure you have the necessary libraries installed. The key libraries are OpenCV, YOLO (from ultralytics), and PIL for handling images.
from ultralytics import YOLO
Step 2: Load the YOLO Model
Specify the path to your YOLO model file and load it.
# Load the YOLO model
model = YOLO("model.pt")  # Replace with your model file
Step 3: Set Up the Camera
Initialise the camera using OpenCV to capture video frames.
cap = cv2.VideoCapture(0)  # 0 for default camera
if not cap.isOpened():
   print("Error: Cannot access the camera.")
   exit()
Step 4: Process Frames and Run YOLO Detection
Read frames from the camera, resize them for YOLO, and pass them to the model for detection.
    ret, frame = cap.read()
    if not ret:
        print("Error: Cannot read frame.")
    # Resize the frame for YOLO
    frame_resized = cv2.resize(frame, (640, 480))
    # Run YOLO detection
    results = model(frame_resized)
    # Extract detections
    for box in results[0].boxes:
        x1, y1, x2, y2 = map(int, box.xyxy[0])  # Bounding box coordinates
        label = f"{model.names[int(box.cls)]} ({box.conf:.2f})"  # Label with confidence
        # Draw the bounding box
        cv2.rectangle(frame, (x1, y1), (x2, y2), (0, 255, 0), 2)  # Green box
        # Draw the label
        cv2.putText(frame, label, (x1, y1 - 10), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
Step 5: Save the Annotated Frames
Save the processed frame with annotations to a file.
# Save the annotated frame
output_path = "annotated_frame.jpg"
cv2.imwrite(output_path, frame)
print(f"Saved annotated frame to {output_path}")
Step 6: Display the Annotated Frames (Optional)
Show the annotated frames in a window to verify the results in real-time.
# Display the annotated frame
cv2.imshow("YOLO Detection", frame)
# Exit loop when 'q' is pressed
if cv2.waitKey(1) & 0xFF == ord('q'):
Step 7: Clean Up Resources
Release the camera and close all OpenCV windows when the program finishes or exits.
cap.release()
cv2.destroyAllWindows()
Full Code Example
Here is the complete code integrating all the steps:
#Load the YOLO model
#Set up the camera
    exit()
    if not ret:
        # Draw the label
#Release resources
cap.release()
