How to augment images and Orientated Bounding Boxes (OBB) labels to increase images amount for YOLO training
This tuturial works for Orientated Bounded Boxes (OBB) models only.
first make sure you import all the libraries
import os
import albumentations as A
make sure the file directory is set correctly. Set your input images file, input labels file, output images file and output labels file.
you can also choose how many variations you want of each image by changing num_aug.
# set file directory
image_dir = r"C:\Users\expemple\datasets\data1\train\images"        # Folder with original images
label_dir = r"C:\Users\example\datasets\data1\train\labels"         # Folder with YOLO format labels
output_image_dir = r"C:\Users\exampledatasets\data2\train\images"   # Folder to save augmented images
output_label_dir = r"C:\Users\example\datasets\data2\train\labels"  # Folder to save augmented labels
# Augment the dataset (e.g., 5 augmentations per image)
augment_dataset(image_dir, label_dir, output_image_dir, output_label_dir, num_aug=5)
copy the following code to import, save and augment the obb labels
def load_obb_labels(label_file):
    #Load OBB labels from the format:
    #class_id x1 y1 x2 y2 x3 y3 x4 y4 (normalized)
    boxes = []
    with open(label_file, 'r') as f:
        for line in f:
            parts = line.strip().split()
            if len(parts) != 9:  # class_id + 4 corners (x, y)
                continue
            class_id = int(parts[0])
            # Parse the 4 corners (normalized coordinates)
            points = [(float(parts[i]), float(parts[i+1])) for i in range(1, 9, 2)]
            boxes.append([class_id, points])
    return boxes
def save_obb_labels(label_file, boxes):
    # Save OBB labels back to the format:
    # class_id x1 y1 x2 y2 x3 y3 x4 y4 (normalized)
    with open(label_file, 'w') as f:
        for box in boxes:
            class_id, points = box
            coords = ' '.join([f"{x:.6f} {y:.6f}" for x, y in points])
            f.write(f"{class_id} {coords}\n")
def augment_obb_image(image, bboxes, img_height, img_width):
    Apply augmentations to an image and update the corresponding OBBs.
    The bounding box points are normalized, so we will denormalize before augmenting.
    # Denormalize the points to the image size for augmentation
    keypoints = []
    for bbox in bboxes:
        class_id, points = bbox
        denormalized_points = [(x * img_width, y * img_height) for x, y in points]
        keypoints.extend(denormalized_points)  # Flatten the list of points
    # Define your augmentation pipeline
    transform = A.Compose([
        A.HorizontalFlip(p=0.5),
        A.VerticalFlip(p=0.2),
        A.RandomBrightnessContrast(p=0.2),
        A.Rotate(limit=20, p=0.5),
    ], keypoint_params=A.KeypointParams(format='xy', remove_invisible=False))
    # Apply augmentation
    augmented = transform(image=image, keypoints=keypoints)
    # Clip keypoints to stay within image dimensions after augmentation
    def clip_keypoint(keypoint):
        x, y = keypoint
        x = max(0, min(x, img_width - 1))  # Ensure x is in [0, img_width]
        y = max(0, min(y, img_height - 1))  # Ensure y is in [0, img_height]
        return (x, y)
    clipped_keypoints = [clip_keypoint(kp) for kp in augmented['keypoints']]
    # Group the augmented keypoints back into their respective OBBs
    new_bboxes = []
    for i in range(0, len(clipped_keypoints), 4):  # Each bbox has 4 keypoints
        class_id = bboxes[i // 4][0]  # Class ID stays the same
        points = clipped_keypoints[i:i + 4]  # Extract the 4 keypoints
        # Normalize the points back to the image size
        normalized_points = [(x / img_width, y / img_height) for x, y in points]
        new_bboxes.append([class_id, normalized_points])
    return augmented['image'], new_bboxes
Finally, copy the following main code to make everything work together
def augment_dataset(image_dir, label_dir, output_image_dir, output_label_dir, num_aug=5):
    Augment a dataset of images and OBB labels in the custom format.
    image_dir: Directory where images are stored.
    label_dir: Directory where label files (.txt) are stored.
    output_image_dir: Directory where augmented images will be saved.
    output_label_dir: Directory where augmented label files will be saved.
    num_aug: Number of augmentations per image.
    if not os.path.exists(output_image_dir):
        os.makedirs(output_image_dir)
    if not os.path.exists(output_label_dir):
        os.makedirs(output_label_dir)
    for image_file in os.listdir(image_dir):
        if image_file.endswith(".jpg") or image_file.endswith(".png"):
            image_path = os.path.join(image_dir, image_file)
            label_path = os.path.join(label_dir, image_file.replace(".jpg", ".txt").replace(".png", ".txt"))
            # Load the image
            image = cv2.imread(image_path)
            img_height, img_width = image.shape[:2]
            # Load the OBB labels
            bboxes = load_obb_labels(label_path)
            if len(bboxes) == 0:  # Skip if there are no bounding boxes
                continue
            # Perform augmentations
            for i in range(num_aug):
                augmented_image, augmented_bboxes = augment_obb_image(image, bboxes, img_height, img_width)
                if len(augmented_bboxes) == 0:  # Skip if there are no valid boxes after augmentation
                    continue
                # Save augmented image
                augmented_image_filename = f"{os.path.splitext(image_file)[0]}_aug_{i}.jpg"
                cv2.imwrite(os.path.join(output_image_dir, augmented_image_filename), augmented_image)
                # Save augmented labels
                augmented_label_filename = f"{os.path.splitext(image_file)[0]}_aug_{i}.txt"
                save_obb_labels(os.path.join(output_label_dir, augmented_label_filename), augmented_bboxes)
depending on how many images you want and have, processing can take quite a while. but if you have done everything right, you can now easily multiply the amount of images to train your model
Having the option to augment images can be really useful to generate more data, especially for models / frameworks that don’t support augmentations out of the box or if it lacks support for specific augmentations that you need to include!
I would like to add a few things about augmentation in general and about augmentations in Ultralytics.
Use of augmentations
It is always important to understand what can and can’t be augmented!
For example, if you need to distinguish objects that are upside down or not you can’t flip your images horizontal or vertical (you could do both in this case).
Augmentations in Ultralytics
By design Ultralytics already does a lot of augmentation.
Make sure to disable augmentations that will hurt your models performance!
