How to build a custom URCaps interface for a UR teach pendant
Based on contributions by icorn.
URCaps let you add your own screens to PolyScope — a custom installation tab or program node with its own GUI, built in Java. Use this when a popup (How to create popups on a Universal Robots teach pendant) isn’t enough and you need a real interface embedded in the pendant.
  • Java knowledge (and HTML, if you choose the HTML variant).
  • A Windows PC with WSL (Windows Subsystem for Linux, e.g. Ubuntu from the Microsoft Store) or a native Linux machine.
  • URSim (the UR simulator) and VirtualBox, so you can test on the simulator instead of the real robot.
  • Visual Studio Code (works well with WSL folders).
  • Maven, plus the other build dependencies listed in the manuals below.
  • UR manuals: Swing tutorial (PDF), HTML tutorial (PDF), URCaps style guide (PDF).
Example interfaces built with URCaps:
1. Decide if URCaps is the right solution
Before you start, be aware of the trade-offs:
  • Requires real Java (and/or HTML) programming, not just PolyScope drag-and-drop.
  • Many standard HTML elements are not available inside PolyScope’s embedded browser.
  • Debugging is limited compared to a normal desktop Java/web project.
  • Uploading a build to the robot takes about 30 seconds each time, which slows down iteration.
If you still need a native interface on the pendant after reading this, continue.
2. Choose Swing or HTML
URCaps code is Java-based. You can build the UI with either:
  • Swing — a native Java UI toolkit. Better suited for more complex interfaces.
  • Java + HTML — an embedded HTML view driven by Java. Better suited for simpler interfaces.
If you’re unsure, start with HTML for a simple interface and move to Swing if you outgrow it.
3. Set up the development environment
  1. On Windows, install a Linux environment: WSL with Ubuntu (from the Microsoft Store) is the simplest route.
  2. Install the dependencies listed in the Swing or HTML manual inside that Linux environment.
  3. Install URSim and VirtualBox so you can test on the simulator instead of the physical robot.
  4. Install Visual Studio Code and open your project folder through the WSL remote connection.
4. Understand the project structure
A URCaps project is a standard Java/Maven project with a pom.xml at its root. At minimum you will have:
  • an Activator class,
  • a Communicator class,
  • a View class,
  • a Service class.
Existing open-source URCaps projects on GitHub are a good reference for how these pieces fit together — it takes a while to get comfortable with the structure, so start from a working example rather than a blank project.
5. Compile and upload
From the root of your URCaps project, run one of:
# install onto a real robot
sudo mvn install -Premote
# install onto URSim (the simulator)
sudo mvn install -Pursimvm
Before running either command, check the IP addresses configured in pom.xml — they must match the machine you’re deploying to (real robot vs. simulator VM), or the upload will fail or go to the wrong target.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: Create a custom interface on a Universal Robot teach pendant.
