When using a custom tool on a robot it is very useful to be able to move and turn the tool from the point of the tool itself, below is a short explanation how to make your own toolframe.
Teach pendant type: A05B-2301-C395
The numbers in brackets are the numbers to press when selecting a menu
- Access the Frames Menu:
- Press the Menu button (located next to the Left Shift button).
- Go to Setup (6).
- Press F1 (Type), then select Frames (2).
- Choose Frame Type:
- Press F3 to select between Tool Frame (1), Jog Frame (2), and User Frame (3).
- View Current Frame Configuration:
- Press F2 (Detail) to view the current configuration for the selected frame.
- Select a Frame Setup Method:
- Press F2 again to choose the setup method. You will have three options:
- Three-Point Method: This method defines the user frame by setting three points that you jog the robot to and press F5 (Record) at each point.
- Six-Point Method: Similar to the three-point method, but based on six specific points for greater accuracy.
- Direct Entry: Use this if you know the exact coordinates for the frame origin and orientation. Here, the (0,0,0) point is based on the center of the ring on Joint 6.
- Guidelines for Using the Jogging Method:
- If defining the user frame by jogging, use a well-defined, small reference point in the workspace for accuracy, for example use a long bolt and move around it.
- Ensure the points you choose are spaced apart and not collinear to help the robot accurately establish the frame orientation.
- Additional Tips:
Typically, you’ll only need to create tool frames. In some cases, you might add a 45 or 90-degree adjustment in the world frame for specific orientations.
- Call frames in programs
 - o To call a frame, use Call_Uframe = X/ Call_Tframe = X. X being the User- or Toolframe you are using.
