Howto grab, save and filter images with librealsense
How to grab, save and filter images
This topic will explain how to grab, save and filter images.
Grab and save a depth images
The code below can be used to grab a depth image and save it.
Context about the code can be found in the comments.
from matplotlib import pylab
from pyexiv2 import Image
import pyrealsense2 as rs
# Create a context object. This object owns the handles to all connected realsense devices
pipeline = rs.pipeline()
pipeline.start()
depth = None
i = 0
# Create a pipeline object. This object configures the streaming camera and owns it's handle
while not depth:
    i += 1
    frames = pipeline.wait_for_frames()
    depth = frames.get_depth_frame()
print(f"Grabbing frame took this many tries: {i}")
depth_data = depth.as_frame().get_data()
np_image = np.asanyarray(depth_data) # Do not use this image for distances!
height, width = np_image.shape # Get resolution
cv2.imwrite("testimg.png", np_image)
# Create an empty array with float values and calculate the distance for each pixel
distarray = np.empty([height, width ], dtype=np.float)
for y in range(height):
    for x in range(width):
        distarray[y,x] = depth.get_distance(x, y)
# Don't call stop before all operations on the depth image are completed! This will break the get_distance function.
pipeline.stop()
max_dist = np.max(distarray)
print(f"max_dist = {max_dist}")
# Create normalize function and apply this function to the array with distances
normalize = lambda t: t / max_dist * 65535 # 16 bit int!
vfunc = np.vectorize(normalize)
normalized_distarray = vfunc(distarray)
# Convert the normalized image with floats to uint16 to get rid of the decimals
img = normalized_distarray.astype(np.uint16)
plt.imshow(img, cmap='gray')
# Write imag and add metadata. You need the max_dist to convert the values back to distances.
filename = "normalized.png"
cv2.imwrite(filename, img)
with Image(filename) as img:
    img.modify_xmp({'Xmp.dc.max_dist': f"{max_dist}"})
# Read out the metadata for confirmation
    data = img.read_xmp()
print(data)
Filter images
Intel has a great example on their Github:
depth_filters.ipynb
You can download it and use it in jupyter notebook. For those that want to apply images directly to depth frames from a Realsense camera I attached a slighly modified version that will use the camera instead of a device from file.
depth_filters.ipynb (10.0 KB)
Good luck!
