Hi,
does anyone know how to change the keyboard settings on the UR5 controller?
The problem: keys don’t match the output. SHIFT + 0 makes an ‘=’ and it is not possible to type ‘[’ and ‘]’ which is quite annoying while programming.
Joost
Hi,
Joost
Apparently there was already a solution availeble. Here is the link: (thanks Mathijs)
There are actually two ways to do this. You can change the keyboard layout with a keyboard attached to the teach pendant using a linux virtual console linux virtual console or through SSH.
Press [ctrl + alt + f1] (Might not work on all firmware versions, this didn’t work on a 1.8.x robot I used recently)
Login with username “root” and password "easybot"
Follow instructions for changing the file
Press [ctrl + alt + f7]
This is usually available on all linux systems. Under Windows you can use Putty
nano /etc/X11/xorg.conf
There you must change the following lines:
option "XkbLayout" "dk"
option "XkbVariant" "nodeadkeys"
to
option "XkbLayout" "us"
option "XkbVariant" "altgr-intl"
press ctr + x to exit
press y to accept changes
press enter to save the file
