Based on contributions by Wouter.v.Velzen.
Doosan officially supports three ways to program their robots: DRL (via DRL/DART Studio, Windows only), ROS2 (Linux only), and the C++ API-DRFL (Linux and Windows, but C++). If you want one cross-platform Python program — instead of juggling a DRL script and a separate PC script over a socket — you can use a community Python wrapper that exposes the C++ API-DRFL as Python functions.
This approach bypasses DRL entirely, so the “DRL only has Python 3.2” limitation from How to connect a Doosan robot to a PC over a TCP socket (DRL Studio and Python) doesn’t apply here — your control script runs as normal, modern Python on the PC, with full access to
pippackages (OpenCV, NumPy, etc.) in the same program that talks to the robot.
- A Doosan robot and control box. This wrapper has only been tested against control box version 2; version 3 should work in theory but needs a one-line change (see Troubleshooting).
- Linux: Ubuntu (an LTS release) — other distros ship different library versions and the build will fail. If you’re not on Ubuntu LTS, run an Ubuntu environment via Docker/Podman with Toolbox, or a VM.
- Windows: the C++ Visual Studio 2017 (or newer) runtime.
Windows builds currently fail to compile (see Troubleshooting) — running Ubuntu via WSL is the current workaround. - Python 3,
git, and the API-DRFL-Wrapper repository (which pulls in the official API-DRFL as a submodule).
1. Clone the wrapper
git clone --recurse-submodules https://github.com/wouter1602/API-DRFL-Wrapper.git
cd API-DRFL-Wrapper
2. Linux (Ubuntu) setup
Create and activate a virtual environment — this is required, since the build has nowhere else to put the compiled Python library:
python3 -m venv .venv
source .venv/bin/activate
Install the required packages:
pip install -r ./requirements.txt
sudo apt install libpoco-dev
Compile the library (this can take a while, depending on your machine):
python3 ./install.py
Run the example script to verify everything works — it should move the robot slightly:
python3 ./examples/minimal_motion_sample_async.py
Before running it, edit the IP address and other settings at the top of the example to match your robot:
IP_ADDRESS = "127.0.0.1" # <- IP of your Doosan control box
PORT = 12345
SPEED = 5.0 # deg/s
ACCELERATION = 5.0 # deg/s^2
MOVE_TIMEOUT = 10.0 # seconds
POLL_INTERVAL = 0.05 # seconds (50 ms polling rate)
VIRTUAL = False # set True to simulate the movement instead of moving the real robot
3. Windows setup (currently broken — see below)
python -m venv .venv
.venv\Scripts\Activate.ps1
If PowerShell refuses to run the activation script, see this fix.
Install the Visual Studio C++ runtime 2017 or newer, then install the Python dependencies and compile:
The build currently fails during stub generation because of a library import issue. Windows users should use Ubuntu via WSL (step 2) until this is fixed.
4. Use the library
The wrapper’s functions and objects mirror the official C++ API-DRFL 1:1, so the Doosan C++ API-DRFL documentation applies directly — just call the same names from Python.
Why use this over DRL or ROS2
- One program. Robot control and everything else your PC needs to do (e.g. OpenCV) live in a single script — no separate DRL program and inter-program socket.
- Simpler than ROS2 to set up, while still supporting more than default DRL programming.
- Cross-platform. The same Python script should run unmodified on Linux and Windows, once the Windows build is fixed.
- Compile once. The C++ extension only needs to be rebuilt when the wrapper itself changes, not on every code edit.
Control box version. The wrapper is only tested against control box v2. To target a v3 box, change the compile flag in setup.py:
extra_compile_args=[
"-std=c++17",
"-O2",
"-fvisibility=hidden",
"-DDRCF_VERSION=2", # <- change to "-DDRCF_VERSION=3" for a V3 control box
"-DPYBIND11_DETAILED_ERROR_MESSAGES",
] if sys.platform != "win32" else ["/std:c++17", "/O2", "/DDRCF_VERSION=2"],
Not every DRFL function is wrapped yet. Control-rights functions, move commands, force feedback, and callbacks are implemented. Missing: welding commands, real-time control commands, and LED functions.
Blocking calls. Standard Python doesn’t have true multithreading, and several wrapper functions block until the robot responds — your script can’t do anything else while waiting. Run robot communication in a separate process using the multiprocessing module if you need to do other work (e.g. run a vision loop) at the same time.
- How to connect a Doosan robot to a PC over a TCP socket (DRL Studio and Python) — the socket-based alternative if you’d rather keep DRL and PC code separate.
- How to send data in a custom format between Python and DRL Studio — designing a data protocol, relevant if you stick with the socket approach instead.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: Controling the Doosan-robot using Python.
