Based on contributions by 20129556, Luthfiandra.
Once you have a working socket between a PC and a Doosan robot (How to connect a Doosan robot to a PC over a TCP socket (DRL Studio and Python)), you need a simple, agreed-upon way to encode the data you send — for example a list of numbers from a vision program. This article shows a lightweight text protocol and a threaded server so your PC program keeps running (e.g. keeps processing camera frames) while it answers the robot’s requests.
DRL Studio’s Python is roughly version 3.2, so keep the format itself simple: plain strings with a separator character (like a comma), parsed with basic string methods (
split,float,int). Don’t rely onjson,pickle, or other library-heavy encodings for the DRL side.
- A working socket connection between the PC and the robot (How to connect a Doosan robot to a PC over a TCP socket (DRL Studio and Python)).
- Python 3 on the PC; DRL Studio on the robot side.
1. Define the text format
Pick a separator and stick to it. A simple, effective format is a comma-separated string of numbers:
send_data = [10, 147, 382]
data_string = ','.join(map(str, send_data)) # "10,147,382"
On the receiving side, split on the same separator and convert back to numbers:
values = data_string.split(",")
x = float(values[0])
y = float(values[1])
z = float(values[2])
2. Define a request keyword
Rather than pushing data continuously, have the robot ask for a fresh value whenever it’s ready, and have the PC reply only to that request. This avoids the robot processing stale or half-written data.
REQUEST = "[QUESTION]"
3. Run the PC-side server in a background thread
Run the socket server on its own thread so the rest of your Python program (e.g. a vision loop) is never blocked waiting on the robot.
import threading
class TcpSocketServer:
"""Threaded TCP server: accepts one client and answers text requests."""
def __init__(self, host, port):
self.host = host
self.port = port
self.server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
self.server_socket.bind((self.host, self.port))
self.server_socket.listen(1)
self.conn = None
self.address = None
def start_server(self):
print(f"Server is running on {self.host}:{self.port}")
def accept_client(self):
self.conn, self.address = self.server_socket.accept()
print(f"Connection from: {self.address}")
def receive(self, buffer_size=1024):
data = self.conn.recv(buffer_size)
return data.decode() if data else None
def send(self, message):
self.conn.sendall(message.encode())
def close(self):
if self.conn:
self.conn.close()
self.server_socket.close()
def socket_thread(tcp_server, data_lock, data_container):
tcp_server.start_server()
tcp_server.accept_client()
response = tcp_server.receive()
if response:
print(f"Received: {response}")
if response == "[QUESTION]":
with data_lock:
data_string = data_container.get("data")
tcp_server.send(data_string)
print("No response received.")
server_ip = "192.168.137.50" # the PC's own IP address
port = 20002
tcp_server = TcpSocketServer(server_ip, port)
data_lock = threading.Lock()
data_container = {}
threading.Thread(target=socket_thread, args=(tcp_server, data_lock, data_container), daemon=True).start()
# Replace this with whatever your program computes each cycle
# (e.g. object coordinates from a vision pipeline)
with data_lock:
data_container["data"] = data_string
The lock protects data_container from being read and written at the same time by the two threads. The main loop keeps updating data_container["data"] with the latest value; the socket thread only reads it out and sends it when the robot actually asks.
4. Request the data from DRL Studio
from DRCF import *
sock = client_socket_open("192.168.137.50", 20002)
while sock:
msg = "[QUESTION]"
client_socket_write(sock, msg.encode())
res, rx_data = client_socket_read(sock)
rx_msg = rx_data.decode()
tp_log("{0}".format(rx_msg))
The robot repeatedly asks [QUESTION], and each time gets back whatever the PC put in data_container["data"] most recently. Parse rx_msg with .split(",") as shown in step 1 to turn it back into numbers.
- Blocking the vision/data loop. If the socket server runs on the main thread instead of a background thread, your PC program freezes every time it waits for the robot to connect or ask a question. Always run the server in a
threading.Thread. - Race conditions on shared data. Always read and write
data_containerinside thewith data_lock:block — skipping the lock can send half-updated data to the robot. - Complex encodings on the robot side. Remember the Python-3.2 limitation on DRL — don’t design a protocol that needs
json.loads()or similar on the robot.
- How to connect a Doosan robot to a PC over a TCP socket (DRL Studio and Python) — setting up the underlying socket connection.
- How to control a Doosan robot from Python using the API-DRFL wrapper — an alternative to sockets: control the robot directly from Python without any custom protocol.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: How to send data from Python to the Doosan in your own custom format, How to integrate TCP/IP communication with python computer vision program and send the data to doosan robot.
