Based on contributions by Shiyar.
Kawasaki’s teach pendant environment (KIDE) programs the robot in AS language, not Python. To drive the robot from a Python program on your PC, you open a socket connection between the two: a raw TCP or UDP link, or a higher-level Python library. This article covers both socket methods and points to the alternatives.
- A Kawasaki robot controller (D, E, or F series) with KIDE / AS language access
- The PC and the robot controller on the same network, with both IP addresses known
- Basic teach pendant setup already done: Kawasaki robot (hands-on)
- Python 3 (only the built-in
socketmodule is needed)
1. Choose TCP or UDP
TCP opens a persistent, reliable connection but needs a handshake before data can flow. UDP has no handshake and is simpler and faster, but doesn’t guarantee delivery. Use TCP for a long-lived session where you don’t want to lose commands; use UDP for short, frequent messages where an occasional dropped packet is acceptable.
2. Connect over TCP/IP
Run the Python server first, then start the robot program that connects to it as a client.
Python server (runs on the PC):
def start_server(host, port):
server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
server_socket.bind((host, port))
server_socket.listen(5)
print(f"Server is listening on {host}:{port}")
client_socket, addr = server_socket.accept()
print(f"Connected by {addr}")
# To receive data from the robot instead of only sending, use:
# data = client_socket.recv(1024)
# if not data:
# break
# print("Received:", data.decode())
response = '1'
client_socket.sendall(response.encode())
time.sleep(2)
response = '2'
time.sleep(3)
client_socket.close()
if __name__ == '__main__':
HOST = '192.168.0.2' # your PC's IP address
PORT = 10001 # non-privileged port (>1023)
start_server(HOST, PORT)
This example just alternates sending '1' and '2' for testing; replace the loop body with your own protocol.
Robot program that connects to the PC (AS language, load in KIDE):
.PROGRAM smr2() ; connects to the PC as a TCP client
tout_open = 60
ip[1] = 192
ip[2] = 168
ip[3] = 0
ip[4] = 2 ; PC's IP address
port = 10001
er_count = 0
connect:
TIMER (2) = 0
TCP_CONNECT sock_id1, port, ip[1], tout_open
IF sock_id1 < 0 THEN
er_count = er_count + 1
IF er_count >= 5 THEN
PRINT "Client Communication with PC has failed"
ELSE
PRINT "TCP_CONNECT error id = ", sock_id1, ", error count = ", er_count
GOTO connect
END
ELSE
PRINT "TCP_CONNECT OK id = ", sock_id1, ", with time elapsed = ", TIMER (2)
END
.END
Robot program that reacts to received data:
.PROGRAM receive_data() ;
WHILE TRUE DO
numbytes = 10
max_length = 10
tout_rec = 60
ret = 0
TCP_RECV ret, sock_id1, $recv_buf[1], numbytes, tout_rec, max_length
IF ret < 0 THEN
PRINT "TCP_RECV error in RECV", ret
$recv_buf[1] = "000"
ELSE
IF numbytes > 0 THEN
FOR i = 1 TO numbytes
PRINT "RecBuff[", i, "]= ", $recv_buf[i]
END
IF $recv_buf[1] == "1" THEN
PRINT "IT IS 1"
SPEED 80 ALWAYS
JMOVE #[ -100.000,-59.995,9.834,13.745,8.050,50.603]
END
IF $recv_buf[1] == "2" THEN
PRINT "IT IS 2"
SPEED 80 ALWAYS
JMOVE #[ -160.000,-59.995,9.834,13.745,8.050,50.603]
END
ELSE
ret = -1
END
END
END
.END
Adjust the joint positions in receive_data to your own program.
3. Or connect over UDP
Robot program (AS language):
.PROGRAM connect_to_pc_by_udp()
timeout = 120
answer_timeout = 3
ip[1] = 192
ip[2] = 168
ip[3] = 0
ip[4] = 10
port = 10010
numbytes = 1
ret = 0
WHILE TRUE DO
TWAIT 1
UDP_RECVFROM ret, port, $cnt[0], numbytes, timeout, ip[1]
IF ret <> 0 THEN
PRINT "No data received within timeout period or error code: ", ret
; continue to the next iteration without halting
ELSE
PRINT "Message: ", $cnt[0]
; send a confirmation message back
$cnt[0] = $ENCODE (/D, numbytes)
UDP_SENDTO ret, ip[1], port, $cnt[0], 1, answer_timeout
IF ret <> 0 THEN
PRINT "Error with the UDP send, code: ", ret
END
END
END
.END
Python side:
def udp_start(host, port, target_host):
server_socket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
print("UDP server started.")
input("Press Enter to send data...")
response = '1'
print("Sending data")
server_socket.sendto(response.encode(), target_host)
time.sleep(2)
HOST = '192.168.0.2' # local IP address
PORT = 10010 # port to listen on
TARGET_HOST = ('192.168.0.1', PORT) # robot IP and port
udp_start(HOST, PORT, TARGET_HOST)
4. Reference: full manual example
Kawasaki’s own TCP/IP communication manual has worked examples starting around page 46, built from four cooperating programs: open_socket(), send(.ret,.$data), recv(), and close_socket(). The exact calls differ depending on whether the robot acts as server or client. See the Kawasaki TCP/IP Communication Manual for details, and these example programs:
- Robot as client: tcp_client.as (3.4 KB)
- Robot as server: tcp_server.as (3.6 KB)
5. Alternative: a bare Python library (experimental)
Instead of hand-rolling the socket protocol, you can use kawapai, an experimental Python library for interfacing directly with Kawasaki D, E, and F series controllers. Its API is still experimental. An improved version of the library (from the Tetrisbot project) is available as tetris bot code incl. improved kawapai library.zip (3.7 MB).
6. Alternative: ROS driver
Kawasaki Heavy Industries publishes an official, unsupported ROS driver. It currently only supports these robot models: duaro1, rs007l, rs007n, rs013n, rs020n, rs025n, rs030n, rs80n.
TCP_CONNECTkeeps failing / “Client Communication with PC has failed”: start the Python server before running the robot’s connect program — the robot is the client here and has nothing to connect to otherwise. Also double check the IP address and port on both sides, and that no firewall is blocking the port.- UDP messages seem to go nowhere: UDP does not confirm delivery by itself; make sure both sides use the same port and that the robot program’s
UDP_RECVFROMis actually running (loop already started) before you send from Python.
- Kawasaki robot (hands-on)
- How to control a Kawasaki robot with the PromoBot Python class
- How to pause a Kawasaki robot on command using a background PC program
Rewritten and consolidated (Sept 2026) from the original student how-to’s: Connect a Kawasaki robot to a Python program on a computer.
