How to calculate motor power, RPM and torque for a conveyor belt
Based on contributions by Okay.
Before you can choose a motor for a conveyor (or any similar drive application), you need to know the power, speed (RPM) and torque it must deliver. This walks through the three calculations with worked examples.
  • The conveyor’s belt speed target, or the length of the conveyor and how long an object should take to cross it
  • The mass of the heaviest object the conveyor needs to move
  • An estimate of the friction coefficient between the object and the belt (or between the belt and its rollers, depending on what’s driving the load)
  • The diameter of the drive roller
1. Determine the required belt speed
Divide the conveyor’s length by how many seconds you want an object to take to cross it.
Example: a 5-metre conveyor, with the object crossing it in 15 seconds:
v = 5 m / 15 s = 0.33 m/s
2. Calculate the required power
Power = Force × Velocity
Where Force is the frictional force resisting motion:
Force = μ × N = μ × m × g
  • m = mass of the object (kg)
  • g = gravitational acceleration, 9.81 m/s²
  • μ = friction coefficient (dimensionless)
Typical friction coefficients:
Situation μ
Standard rubber conveyor belt on metal rollers 0.02 – 0.05
High-friction surfaces (textured or coated belts) 0.1 – 0.3
Low-friction applications (plastic belts, specialized coatings) 0.01 – 0.02
Once you have Force and Velocity, Power = Force × Velocity gives you the required power in watts (1 N·m/s = 1 W). Add a safety margin of 10–20% on top of the calculated value.
:warning: Check: the original notes for this calculation stated Power = Force / Velocity, which is dimensionally wrong (that would give N·s/m, not watts). The correct relation, used above, is Power = Force × Velocity.
3. Calculate the required RPM
You need the roller’s diameter and the target belt speed.
First, find the roller’s circumference:
circumference = diameter × π
Example: a roller with a 45 mm diameter:
circumference = 45 mm × π = 141.4 mm = 0.1414 m
Each roller revolution advances the belt by one circumference. So the number of revolutions needed per metre of belt travel is:
revolutions/metre = 1 / 0.1414 m ≈ 7.07 rev/m
Multiply this by the target belt speed (in metres per minute) to get the required RPM.
Example: for a target speed of 20 metres/minute with the 45 mm roller above:
RPM = 20 m/min × 7.07 rev/m ≈ 141.5 RPM
4. Calculate the required torque
Torque = Power (W) / Angular speed (rad/s)
Convert RPM to angular speed by multiplying by 2Ï€/60.
Example: at 141.5 RPM:
Angular speed = 141.5 × 2π/60 ≈ 14.8 rad/s
Divide your calculated power by this angular speed to get the required torque in N·m. Use this torque (and the calculated RPM) to select a motor with matching or better specifications.
Rewritten and consolidated (Sept 2026) from the original student how-to’s: How to calculate and choose a motor for a conveyor (or other applications).
